69 automatic to 4 speed conversions
Old Jul 6, 2012 | 03:45 PM
jeffjp's Avatar
Default 69 automatic to 4 speed conversions
Can anyone comment on how solidly a 69 automatic can be converted to a 4 speed Muncie? I mean, if a good mechanic does the conversion, will the end result be as reliable and solid as a factory 4 speed? Has anyone done this and had good (or bad) luck?
Thanks,
Jeff
Old Jul 6, 2012 | 04:00 PM
Years ago I had a different 69 and converted it from auto to stick. I got most of the parts I needed from someone selling parts off a wrecked Camaro; trans, shifter, driveshaft (the yoke splines are different), pedal assembly, z-bar and rods. Flywheel and clutch assembly I bought new. The rest is a straight-forward swap, as your car was built to accommodate either. You already have a hole in the firewall (has a cover screwed on) for the clutch rod to pass through. The subframe has threaded holes to mount the z-bar bracket. And your engine (if it's still vintage) should have the threaded hole for the pivot ball.
ngomez11
Oct 25, 2010 08:45 PM
91camarorsman
Mar 2, 2009 09:58 PM
976Speed
Feb 10, 2007 07:33 PM
camaraholic
82-92 V8 Tech
Jan 4, 2006 03:48 PM
99CamaroOwnr
Nov 28, 2005 09:28 PM
