68 dash top panel removal
Old Mar 27, 2010 | 05:05 PM
black68's Avatar
Default 68 dash top panel removal
Anyone have pics of how to remove the top panel from the dash of a 68? I googled it and looked through all the posts here and found nothing. I have cut through 6 of the 22 spot welds using a cold chisel and a hammer but it is taking forever. Is there a better way? If you don't know where I can find pics I'm open to advice on how to do it from anyone who has done it or has seen it done.
Old Mar 29, 2010 | 12:17 AM
31Bravo's Avatar
I'm assuming you are talking about the dash panel. I have to cut mine out here pretty soon myself, my plan of attack was to grind out as much of the weld as I could and hit it with the air chisel, then grind it flat in prep for the new panel.
Old Mar 29, 2010 | 10:16 PM
black68's Avatar
OK, I got the top of the dash separated from the front. In case anyone wants to know I drilled the spot welds from the top and then used the cold chisel to separate the panels and cut any remaining slivers of weld. I used a 7/16 drill bit. Only took me about half an hour. Not nearly as bad as I thought
Techbox
Aug 5, 2012 09:00 PM
69SS427
Feb 3, 2011 01:35 PM
kats69
Sep 23, 2009 10:33 PM
South Australian 68 SS 396
Jul 28, 2009 08:19 AM
1995Camaro
Mar 20, 2009 12:09 PM
