68 Camaro speedometer problem HELP!!
Old Jan 3, 2011 | 02:17 PM
Smee78's Avatar
Question 68 Camaro speedometer problem HELP!!
Hi all,
Years ago when my Camaro was a daily driver the speedometer needle broke off of the gauge face / just the pointer part that points to the numbers, the round part is still attached to the gauge. Now I am in need of help, how do you get the old needle(round part) off of the pin that it rides on? I tryed to get it off and it did not budge. Are there people who can fix it or is it a total loss? Who can rebuild these?
Old Jan 3, 2011 | 03:59 PM
shevrolay's Avatar
Could try these guys:
http://www.mechanicadvisor.com/sc/su...utomotive.aspx
This response is brought to you by the power of Google, for I am in Idaho!!!!
Old Jan 3, 2011 | 07:40 PM
scotty62's Avatar
****s speedo in AZ can take care of your problem, and detail the rest
Old Jan 3, 2011 | 07:50 PM
scotty62's Avatar
Default the opposite of richard its a real bus
Check him out well known in Az A huge car community Barrett jackson and so on
Old Jan 3, 2011 | 07:57 PM
scotty62's Avatar
Default the same as richard its a real biz
Old Jan 3, 2011 | 08:04 PM
scotty62's Avatar
Default Re illegals
They might be in AZ Smee
Old Jan 4, 2011 | 03:07 PM
Smee78's Avatar
Just for all you guys & gals awaiting to see if it is a real site..........it is! Di*k's Speed-O-Tach is a real business in AZ.
Thanks,
Scotty62
Old Jan 4, 2011 | 08:27 PM
scotty62's Avatar
Good luck Smee78 talk to you later scotty62
Old Jan 4, 2011 | 10:49 PM
burnt68's Avatar
December 2010 ROTM
before you call the guy in AZ i think i have another 68 gauge set let me look and if i figure it out and pull the needle i will send it to you!!!
Old Jan 9, 2011 | 06:36 PM
Smee78's Avatar
Burnt68 that would be awsome, I just dont want to break the stud off of the speed-o if there is a special way of doing it.
