68 Camaro 327 SB Tuning HELP NEEDED!
Bought the car about 1 month ago and I'm still trying to get it to work properly. Had one speed shop look at it and they told me that compression was good (9:1), timing, spark plug gaps, wires, and they installed the new MSD distributor and told me to try the jets, squirter, and they borrowed me a 600CFM Holley and a 750 square bore (have a OEM square bore manifold to swap if necessary) to try(didnt yet). Also mechanic said that since I have glass packs there could be and issue with them and to try disconnecting.
Existing problem: engine will make a popping noise and hesitat out of the exhaust when gas peddle in hammered at about 4-5K RPM. Also off the line, even in first, the tires wont light up at all. Based on the amount of rubber on the underside by the rear tires it should be pretty easy with this car. ANY ADVISE WOULD BE APPRECIATED.
68 Camaro Stats.
-327 V8 Small block (0.30" boared/flat top pistons)
-Brand new MSD HEI distributor (~28 degrees advanced)
-Brand new MSD ignition wires
-Brand new champion spark plugs
-Brand new Holley 670CFM (Vacuum secondaries/Electric Choke)
-Put in .35 squirter to fix bog on low end (helped alittle)
-Put in #70 jets on primary side to fix popping at 4-5K RPM (NO HELP)
-Mid range cam actual size unknow
-202 Valves/World Headers
-3 Speed Auto
-3000 Stall converter
-Turbo 350
-12 Bolt rear end
-Power track locker rear end with 4/10 gears
-Vacuum is about 14 at idle
68 Camaro Stats.
-3 Speed Auto
-Turbo 350
-12 Bolt rear end
reaperchild
LS Series Tech
05-14-2009 09:31 PM
