'67 won't idle: help
Old Mar 3, 2011 | 07:18 PM
Vetteman61's Avatar
Default '67 won't idle: help
Hi,
I have a '67 camaro with a 350. It has sit for about a year and when I got it going again it was having trouble idling for about a week. It then cleared up. Yesterday it started again.
If it does idle it will idle around 300 rpm, barely running. If I'm at a stoplight (it's a 4 speed) I put it in neutral and try to rev it up but it won't stay at a constant RPM. It will rise and fall. If I'm going through a parking lot in 1st gear very slowly with my foot at a constant rate it wants to lurch (looking like i'm trying to run over people).
While I'm driving down the road there are small hesitations. I guess you might call it a sputter.
If I floor it it will go fine. I feel it has something to do with the fuel. I have a picture of the inline glass fuel filter I can upload if that would help. I feel there isn't enough gas in it at times but I'm not sure.
Anyone have any ideas?
Thanks,
Brandon
Old Mar 3, 2011 | 09:02 PM
JG69's Avatar
Check the vacumn hose going into the distributer. I would also spray carburator cleaner and clean those jets inside. If the car was sitting for a long period of time, you may also be dealing with bad gas.
Old Mar 3, 2011 | 10:15 PM
camaroboy68ss's Avatar
June 2010 ROTM
Ride of the Year 2010
also check your plugs wires cap and rotor to make sure your getting a good consistant spark
Old Mar 3, 2011 | 10:24 PM
ElkyHolik87's Avatar
I say it's the carb and bad gas... Run all the bad gas out of it till it's fresh again, replace fuel filters. Then get your carb rebuilt. I thought my edelbrock and 350 was running fine. I rebuilt the carb for 130 and holly smokes it's like a woke up the beast. It runs way better and pulls way harder.
Old Mar 3, 2011 | 10:54 PM
If you still have the old points & condenser ignition, check your dwell. The points could be burned, corroded, or not opening and closing much if the wiper is worn.
Old Mar 4, 2011 | 07:17 PM
Vetteman61's Avatar
Thanks for the responses. One more question: It has HEI and a vacuum advance but it does not seem to turn the distributor. Is an HEI supposed to physically turn or is that internal on an HEI?
Thanks,
Brandon
r00tk1ll
Feb 6, 2015 10:25 PM
Rustyshackleford1911
Dec 27, 2014 09:32 AM
millspec96ss
Dec 12, 2009 10:47 AM
92rs_guy
Apr 9, 2009 11:20 PM
6v49der
Jan 3, 2007 01:51 AM
