67 Wiper Issue
Old Mar 5, 2013 | 12:53 PM
ezinirving's Avatar
Default 67 Wiper Issue
Have a 67 - the wiper motor does not turn when switch is activated - by forcing the crank arm to move from the park position (less than a half-inch), the motor turns and runs somewhat normally, however, as the crank arm returns to the park position, the rotation slows (like it is straining) but then picks up speed as it "leaves" the park position.
This issue occured with the "old" wiper motor, I changed it and put a new one in and the same operation exists.
All wiper transmission joints are lubed and move freely.
Seems to me that there is just not enough power to start the motor out of the park position - is this an electrical issue?
Any thoughts or experience with this?
Old Mar 8, 2013 | 10:05 AM
bruce69camaro's Avatar
Is the wiper motor or switch properly grounded?
Grounding issues can cause all sorts of problems.
Old Mar 15, 2013 | 08:46 AM
ezinirving's Avatar
Wiper motor now works - ended up being wiper switch ground - thanks for the help
Old Mar 15, 2013 | 09:00 AM
I can see clearly now the rain is gone......
If you're one of these youngen's, that's part of a song.
Glad it worked out for ya.
Bruce
Old Jan 5, 2017 | 08:57 PM
MikeJ67's Avatar
Old thread, but same problem. My 67 wipers don't work when I turn the switch on, BUT if I push the washer button, they work fine. SO, the motor must be okay? What issue am I not able to see here on my own? All the wires appear to be correct. Could it be the switch itself?
Thanks in advance. Any advise from you guys that have handled this issue would be greatly appreciated.
Old Jan 8, 2017 | 06:05 AM
Everett#2390's Avatar
More than likely, the switch as washer -wiper motor power takes a different route than wiper only power.
Thestoat
Jun 25, 2013 10:35 AM
dallas612
Jun 1, 2013 11:07 AM
TomS68
Apr 27, 2007 02:38 PM
rpk250
Apr 1, 2005 04:03 AM
