67 rs horn weird problem w/pin in steering wheel
Hi, horn on my 67 rs went out. Horns are good, relay is good. Went at pin under button in steering wheel. Pin i put in years ago that did work was no longer touching the contact piece down in the steering wheel when compressed. Ordered another pin set; it came with a longer pin...okay, put it in. This pin didn't reach either. I had to take a long machine screw the same diameter as the pin and cut it to a length that would compress and make contact. It works, but.....what happened??????? Why don't the regular pins work anymore?????? Thank you
