67 Front end Rebuild
Old Nov 6, 2008 | 07:20 PM
1995Camaro's Avatar
Default 67 Front end Rebuild
I am rebuild a 67 I purchased in March. I"m in the process on sandblasting the frame assy and painting but I'm confussed and looking for some suggestions on which front end bushing's to use. I will be driving It but also showing the car. I'm looking for good performance but with no noise. Thanks Guy's
Old Nov 6, 2008 | 10:36 PM
1969 SS's Avatar
Default RE: 67 Front end Rebuild
as long as you use the grease that is included with whichever bushings you buy, you will have no problems with noise. it usually sucks to apply, but use plenty of it (it doesn't hurt to buy extra). a lot of people skimp out on it and thats why they have noise/squeaking problems
Old Nov 7, 2008 | 09:37 AM
gearheadtx's Avatar
I am using rubber bushing and have not seen any issue with performance.
Old Nov 7, 2008 | 06:40 PM
JRs72RS's Avatar
February 2009 ROTM
Go with urethane bushings. Rubber is alright but under performance conditions they can exhibit deflection(flexing) that can take some parts out of alignment. Also, rubber will age at a rate that is 4x that of urethane. The only drawback is the subframe mounting bushings, the urethane bushings will transmit bumps to the body a bit more than rubber. Some people find that objectionable.
69SS is right, use the grease that comes with the kit, use plenty!
Old Nov 8, 2008 | 02:31 AM
1969 SS's Avatar
ORIGINAL: gearheadtx
rubber is what they used stock, so you would never see any issues from using that. the only problem with rubber, is that you lose so much performance over what is available today
Old Nov 16, 2008 | 07:23 PM
1995Camaro's Avatar
I was looking at Graphite Impregnated Polyurethane bushings at Performance specialites. I was think of a Complete kit The "G" Machine Kit 11. Any other Suggestions ..
Thanks Gary
fastb
Jan 12, 2012 01:41 PM
ENTRDRGN
Apr 8, 2011 10:27 AM
madmaxwell1987
Nov 27, 2010 06:40 PM
jenz
67-69 V8 Tech
Oct 30, 2009 08:13 AM
buckmaster
Mar 2, 2008 12:06 PM
