67 Camaro U-Joint style
need to replace u-joint. I am told to go with a non-greaseable Steel U-joint. My question that i dont know how to answer is.
what style U-joint are in the 67?
is it a 7290 style or a 1350 style?
This is the kind to get: http://www.federalmogul.com/en/After...engthU-Joints/
You can get them at rockauto.com, or other supply houses. They're greasable, but on the end caps where it doesn't affect strength. Ones that are greasable in the cross assembly can be weaker, but it's not really an issue if you have a stock engine car.
Sometimes you have to remember the real life questions.....is all the stuff I read about the stuff I want what I really need to know...or as Camaro 69 stated, with a stock motor it matters not. Sometimes the the best weak link you can have is a u-joint.....cheap and easy to fix....make it stronger and you move to the next weak link....spyder gears....
Tabascoboy
Tabascoboy
mike83camaroBA
12-19-2005 11:21 AM
