67 Blinkers Not Centered
Old Jun 16, 2013 | 08:05 AM
Roger3's Avatar
Default 67 Blinkers Not Centered
67 Camaro with tilt steering column.
Blinkers work fine for right turn but not left.
When turning on left blinker, blinker arm will not go down. Feels like its hitting something. If I turn steering wheel a few degrees it will work but turns off almost immediately.
Seems like the blinker switch or cam that turns blinkers off is not quite right and needs to be rotated/adjusted. Can they be adjusted or do they have to be replaced?
Steering wheel is centered.
Roger
Old Jun 16, 2013 | 09:06 AM
Stock steering wheel, or aftermarket?
Old Jun 16, 2013 | 09:16 AM
Roger3's Avatar
All stock
Old Jun 16, 2013 | 10:53 AM
You're going to need to remove the steering wheel then, to see what's going on in there. See if someone messed with the cancelling pin on the steering wheel. Or the cam on the switch could be broken.
Old Jun 17, 2013 | 07:37 AM
Roger3's Avatar
69 Camaro,
Thanks for the info.
I'm gonna dig into it tonight and see what I find.
Roger
Old Jun 18, 2013 | 07:57 AM
Roger3's Avatar
Took it apart last night.
The black plastic part with the cam that cancels the blinkers was cracked/broken. I ordered a new one from Classic Industries.
Question - What goes on the shaft first, the heavy spring or the black plastic ring with cams?
On mine the spring was on first with the cam on top of it but it just didn't seam to look right. I have the AIM manual, shop manuals, etc, but can't find an exploded view of my steering column to confirm it.
I have the auto tranny shift on console with tilt.
Roger
Old Jun 19, 2013 | 03:06 PM
Roger3's Avatar
Jim Shea (steering column extraordinaire) answered my question.
In case someone else down the road has the same question, the spring goes on first, then the cam canceling piece.
Roger
aldistuck
Jul 11, 2014 08:52 PM
B_Dubya
Jul 30, 2013 01:12 PM
andersonSLPZ28
Nov 22, 2009 03:41 PM
xXOfNiRXx
Jun 26, 2008 10:27 AM
94z28chevy
82-92 V8 Tech
Jun 24, 2008 10:55 AM
