67 A-Arm bushings/ball joints
Old Jan 10, 2009 | 08:02 PM
1995Camaro's Avatar
Default 67 A-Arm bushings/ball joints
I am having a hard time removing the bushings from my A-Arms.does any one have any good suggestions for the removal of these stubborn things?. Also having a hard time removing the lower ball joint from the A-Arm looking for some good suggestions..(A-Arm is out of car)Thanks Guys
Old Jan 10, 2009 | 10:31 PM
68RSSScamaro's Avatar
Default RE: 67 A-Arm bushings/ball joints
I took mine to an automotive machine shop to have them pressed out and the new ones pressed in.Actually I took the project to Columbus Spring located in Columbus Ga. They specialize in suspension repair. These suspension shops are usually jiggedto prevent bending the components.[/align]I remember grinding the rivets off to remove the balljoints and using nuts and bolts to install the new ones. I think it would be worth your time to have a suspension shop assis with this project.[/align]
Old Jan 11, 2009 | 12:21 AM
frostlime69's Avatar
grind off the rivets then use nuts and bolts for the new bushings.
Old Jan 12, 2009 | 11:10 PM
orocker's Avatar
December 2011 ROTM
Santas Little Helper
Hammer the **** out of it.....lol. We found a tool that somewhat helped us remove the old ones, but it was a real.....well pain to get the new ones in.
adam86107
Mar 28, 2014 11:03 PM
Shalamara
Jan 10, 2012 11:01 PM
vjw757
Jun 24, 2011 11:43 PM
danschultz
Mar 13, 2010 01:35 PM
rdman
Jan 24, 2008 09:10 PM
