67-69 Center Console with Clock Mount
That is strange. How about a washer or two between the mounting tab and the plate so the clock won't get pulled forward when tightened....if that's what's happening?
Camaro69
Your right yesterday Sunday morn I removed the lens from the clock then mounted it into the plate.
I noticed it was a little tight and pressure was up against the clock. So I bent the top tab up just a little then screwed it down.
It has kept perfect time.
So this morning I am going to put the Lens back in and try it that way and run it for another day. Will let you know the results, and thanks for the advice.
Brianstevens03
03-20-2009 11:16 PM
