1/2 full when empty?
Last time I had to replace a sending unit, original Delco parts were still relatively cheap! Now one is almost a couple hundred bucks for your car.
Places like Dynacorn, Goodmark make or sell them. Rockauto carries one brand for yours, Spectra. That one and OER, I don't know where they're made. Dynacorn or Goodmark either for that matter, but they're a good name for body parts. Make sure you get the right tube size, 5/16 or 3/8, as well as single outlet or double (return line). Here's a couple:
Dynacorn Unit
Goodmark Unit
Dynacorn Unit
Goodmark Unit
Well, its fixed. I picked up a new sending unit today and installed it. It bench tested at 97 ohms so it reads just a little past full with a full tank of gas. Thanks for all your help and advice on this. Now I am on to the radio. I want to get a radio that has a jack for IPOD hookup and a couple of speakers to mount in the rear/trunk. Any recomendations anybody?
to get it in did you completely drop the tank ?
I have been looking at radios also..wanting one that will fit
into the dash w/ out cutting.
classic ind.
vintage car radio .com
vintage vibes .net
these links are not exact..
but close.
classic ind.
vintage vibes .net
but close.
Yes. You pretty much have to drop the tank in order to remove the sending unit. It wasn't that hard at all. I would recommend getting new fuel line (about 4 inches) and new rubber filler neck also. Mine were pretty dried out. Filler neck was cracked on the tank side. I also put in the anti squeek pads...they were missing. Just try to burn up as much fuel as possible first. I had about 5 gallons left in my tank. Not impossible to do but it would have been MUCH easier withless fuel.
ladybridgeport
Apr 5, 2010 08:44 PM
