Help anyone ?? Hoping someone may know about crankshaft work.
Old Apr 18, 2023 | 02:07 PM
Caseyed8690's Avatar
Default Help anyone ?? Hoping someone may know about crankshaft work.
I had work done to the top of my crankshaft and now all of a sudden the bottom half is screwed up. Could that of been caused by poor work by the macanic?
Old Apr 18, 2023 | 06:42 PM
Top? Bottom? Not sure what you mean,what exactly did you have done?
There's not much you can do with a crankshaft without taking the motor apart and having the crank out and in a machine shop,what do you mean by top and bottom?
I've never heard of a crank having a top and a bottom.
Old Apr 19, 2023 | 07:43 AM
Nardulli's Avatar
Default No such thing
the crank has bearings for the mains, facilitating the smooth operation of the rotating mass. And bearings on the throws for connecting rods. The tolerances are critical. Too loose and you will see lower oil pressure. Too tight and you won’t have the oil film needed and you’ll likely spin a bearing.
there’s a front seal which is typically trouble free. The rear seal setup on LS engines is prone to leaks. Bad design.
describe the problem please.
Old Apr 20, 2023 | 06:42 PM
joelle king's Avatar
what did the mechanic do ?
BZpbp
Feb 7, 2012 05:22 PM
jason7504
Jul 2, 2009 01:48 PM
jason7504
Jul 2, 2009 01:22 PM
02v6camaro
Feb 9, 2009 11:16 AM
02CamaroV6
Feb 19, 2007 11:30 PM
