2010+ V8 Tech For you LS3 and LSA guys to discuss modifications.
Camshaft
Old Aug 1, 2022 | 11:15 AM
Moose1488's Avatar
Default Camshaft
Hey new camaro ss owner I have a 2010 camaro ss has a Magnusson tvs2300 supercharger, as far as I know all internals are stock I would like to put a btr stage 2 or 3 camshaft but have been told multiple things like replace valves due to the hollow design also I need to install a higher volume fuel pump can anyone chime in with what they have done or tried
Old Aug 2, 2022 | 06:41 AM
Cheeks's Avatar
August 2011 ROTM
If/When you order from Brian at BTR, he'll be able to tell you exactly what to do but typically, nobody really messes with the stock valves until a point in which you really start revving the nuts off the motor, I wouldn't worry about it. As for the oil pump, your LS3 pump is actually pretty good already, but a lot of guys will run the melling pumps, I've run them in all of mine, when the cam is being done, the oil pump and timing chain are right there, so its best to get them all done at once.
To sum it up. If you're doing a camshaft
melling high volume pump
ls2 timing chain + sprockets
Ask brian about any other upgrades, might be worth buying the trunion kit also for the rockers
taylordtriplett
Dec 10, 2018 07:34 AM
thechadmanhl2
Jan 16, 2012 08:48 AM
TrojanRay2418
Aug 13, 2011 03:57 PM
STi300whp
VS
Dec 5, 2009 06:12 PM
camaro_burns_all
Apr 6, 2009 12:34 PM
