2010+ V6 Tech discuss modifications to the all new 3.6L v6 here.
Unwanted PO442 code
Old 05-23-2010 | 03:13 PM
maro48's Avatar
Default Unwanted PO442 code
I have a 98 V6 Camaro and I have a PO442 code that is driving me crazy. I bought a new gas cap and checked all the vacuum lines that I know of. I did notice that on the evap line that reads "caution fuel vapors" that I see a service port that has a green cap. Sounds crazy but it looks like someone burnt it somehow almost in half. I checked it out with carb cleaner when the engine was cold and there was no idle change. Is that suppose to be a shrader valve of some sort or just a dust cap for the service port? If there is a pin hole in that cap, would that cause the code to show up? Another question is when I replaced the gas cap how long does it take for it to clear if that was the problem. It wasn't cleared at the parts store after I put it on.
Old 05-23-2010 | 03:33 PM
pezlow's Avatar
I work at an auto parts store and see this code a lot. It could be the EVAP cannister purge/vent valve solenoids or the cannister itself. These things saturate over time and need to be replaced. I hate trying to diagnose the 442 code but I hope this helps. Best of luck. Also, you could disconnect your battery for five minutes and clear the code or drive about 40 miles to see if it clears.
Southern Pride
08-09-2011 07:06 PM
warbeckn
82-92 V8 Tech
09-24-2010 08:57 PM
tode5tool
01-07-2009 10:16 PM
tycomps
02-16-2008 10:56 PM
350rs
05-16-2007 10:02 PM
