maro48 |
05-23-2010 02:13 PM |
Unwanted PO442 code
I have a 98 V6 Camaro and I have a PO442 code that is driving me crazy. I bought a new gas cap and checked all the vacuum lines that I know of. I did notice that on the evap line that reads "caution fuel vapors" that I see a service port that has a green cap. Sounds crazy but it looks like someone burnt it somehow almost in half. I checked it out with carb cleaner when the engine was cold and there was no idle change. Is that suppose to be a shrader valve of some sort or just a dust cap for the service port? If there is a pin hole in that cap, would that cause the code to show up? Another question is when I replaced the gas cap how long does it take for it to clear if that was the problem. It wasn't cleared at the parts store after I put it on.
