What the deal with the Bluetooth?
Old Aug 21, 2012 | 10:37 PM
Rombama's Avatar
Default What the deal with the Bluetooth?
I jsut bought a 2012 1LS, the base model with the basic stereo, I assumed when they said bluetooth standard that it would work with music on my iphone but so far I cant get it to work.
Is the bluetooth for phone use only? I have an older blue tooth adapter for an ipod, I wonder if it will work with that?
Is there a 3mm jack to plug in an ipod somewhere to the base stereo? Cant find one anywhere. there has to be atleast an input jack right?
thanks
Old Aug 21, 2012 | 10:48 PM
Rombama's Avatar
alright, i just found the plug in the center consol, it looked like a dummy at first but it works. But is the bluetooth only for calls then?
Old Aug 21, 2012 | 11:15 PM
BasicConcepts's Avatar
Technical User
Iirc you can play music through the bluetooth.
Edit: Google "music through Bluetooth 2010 camaro" I'd post up a link for you but I'm on my fone and its a pita.
Old Aug 22, 2012 | 01:05 AM
GuitarJozz's Avatar
From what I've researched about it, you can only play music from a bluetooth compatible device if you have the PDIM module(USB port) installed and programmed. I have a 2012 Camaro 2LS and was wondering the same thing. After searching for awhile, you need that PDIM USB module(Personal Device Integration or something) for bluetooth music playing.
I could be wrong though....
Old Aug 22, 2012 | 11:42 PM
GuitarJozz's Avatar
Maybe you can try pairing your phone again, but see if you can set it up as a bluetooth music device, instead of a hands free calling one. If I get a chance, I'll try that and let you know what I find out. But I'm pretty sure you need that PDIM module...
Old Aug 23, 2012 | 07:30 PM
Rombama's Avatar
yep, it seems that you need the USB option to have the functionality, which is fine since the mp3 jack works fine in most cases. however I see you can buy kits,
2010 2013 CAMARO PERSONAL DEVICE INTERFACE MODULE (PDIM) (IPOD ADAPTER) 22872777 | eBay
Old Aug 24, 2012 | 09:08 AM
Chevrolet Customer Service's Avatar
Official GM Representitive
thanks
On page 7-19 in your owner's manual it states:
Bluetooth Setup Menu
The Bluetooth Setup menu can be accessed with or without a device attached to the USB port. To select the Bluetooth Setup menu when a device is attached to the USB port and active:
1. Press the MENU/SELECT **** while in the iPod, Zune, PFD, or USB device main menu.
2. Select Bluetooth Music Setup.
To select the Bluetooth Music Setup menu when a device is not attached to the USB port, or when a device is attached to the USB port but not active:
1. Press the CD/AUX button until AUX is the active source.
2. Press the MENU/SELECT ****.
3. Select Bluetooth Music Setup.
To select the Bluetooth Music Setup menu when a Bluetooth device is connected and active:
1. Press the MENU/SELECT ****.
Please let us know if this was helpful!
Brandon
Old Aug 25, 2012 | 09:59 PM
Rombama's Avatar
Brandon
nope, I dont think it works unless you have the $450 preminum sound & USB option which is only available on the 2lt/2ls versions right?
Old Aug 27, 2012 | 07:57 AM
I apologize for that. Yes, you would have to have the Convenience and Connectivity Package in order for the Bluetooth to play music for you.
Brandon
linsys
Nov 4, 2018 03:49 PM
grasshopper645
Jul 22, 2015 07:54 AM
Mac 7
2010+ V6 Tech
Jul 12, 2012 11:33 PM
Rubber Peeler
Dec 7, 2011 04:07 PM
duck90
Aug 28, 2010 01:25 AM
