soo couple things..
Old Jul 19, 2014 | 01:31 PM
TheDevilsBreed131's Avatar
Default soo couple things..
Alright so there's a couple thongs I kinda need help with. As far as figuring out how to take care of it myself or do it the smart way, my dear belt buckle has been having an issue. It won't latch right u less I hold the release button down and slide the base of the latch in and let go of it to lock in..how can I go about fixing this issue myself? I took it to the dealer and they wanted 100 bucks for it to get fixed. Pretty ****in lame. Any ideas?
Also, I THINK, I may have a radiator leak? Not sure what it was. But I noticed my engine has been hotter than normal and it seems like the fan runs more often to cool it down. I checked my coolant and it wasn't empty but it also wasn't full. So I poured more coolant in, but then it started leaking and spilling down by the bottom right side of the car. Any idea on what that could be?
Old Jul 19, 2014 | 08:50 PM
GaryDoug's Avatar
Radiator issue:
First, visually check the radiator-to-engine coolant hose for leaks.
If not fault is found there, remove the battery and visually check the overflow line from the radiator to the overflow tank. Also look to see if the overflow tank is leaking.
imcdowel
Feb 8, 2010 12:50 PM
3.4_V6_Maroboy
Oct 14, 2009 02:48 AM
RFxCamaro
Sep 8, 2009 06:40 PM
86sleeper
82-92 V8 Tech
Aug 16, 2007 02:28 PM
