Rear Differential in 2011 Camaro LS
Old Sep 15, 2011 | 11:17 AM
ginap2011's Avatar
Default Rear Differential in 2011 Camaro LS
I was wondering if anyone out there has been having an issue with their 2011 camaros? When I make a turn, slow or fast, engine on or off the back end makes a noise. It is the same noise as if the power steering fluid was out. But that has been checked. I took it to the dealer and they said it sounded like the rear differential...they did not have an answer for it or do anything to fix it. My concern is, that if it IS the rear differential, could my tires be wearing faster than they should, in addition to causing later problems. The car has 2,000 miles on it...much to soon to have problems...Anyone out there have the same issue?
Old Sep 16, 2011 | 08:36 AM
Chevrolet Customer Service's Avatar
Official GM Representitive
ginap, I would suggest getting into contact with our Customer Assistance team in regards to this. I can setup a case for you if you'd like. They would work with you and your dealer to resolve this issue. All you would need to do would be to send me your contact information and I can get you all setup. I hope this helps.
Jeff Morris, Chevrolet Customer Service
Old Sep 19, 2011 | 05:49 PM
runner66's Avatar
October 2010 ROTM
LOL how to you make a turn slow or fast with the engine off
Old Dec 25, 2011 | 01:14 PM
Snakebit's Avatar
Default rear dif noise
I had the same problem with my '11 SS.
I took it to the dealer & they said the was a buletin on it & they had to add an additive for the rear end. They did & problem solved. Hope this helps.
Old Dec 25, 2011 | 07:35 PM
Failed Devices's Avatar
more than likely its just the posi unit locking and unlocking; this will happen when cornering, accelerating hard and decelerating hard. This is pretty normal for all cars with a LSD, but making sure the correct amount of friction modifier is there is also important.
rkr29kracing
LS Series Tech
Sep 27, 2006 01:02 AM
