Exhaust Systems
TO anyone that has changed their stock exhaust systems for the SS----
Are there any systems out there for the 2010 and 2011 which do not require you to cut into the trunk area of the car to make the mufflers fit?
Ok..... I guess that was a dumb question after reviewing websites for the most popular systems it appears none of them do sorry
a shop told my neighbor that they would have to cut his because of the ground effects kit on his 2010 ss ???? Who knows
The flowmaster had different kits depending on ground effects or not, but you probably figured that out by now. I had never heard of cutting the trunk. Also I wouldnt bother wasting the money getting a shop to install it (the FM anyway), it was like 6 bolts and the stock slid right out.
It sounded good with nothing from cat back, but I'm sure that would be frowned upon. I just cut off the muffs so I could store the stock in my shed, but now want to put it back on just for SNG.
Yeah, I dont know who told him that they had to cut anything on his vehicle I will be sure not to go there. I have a friend that is now a manager at a local meineke so to prevent me from screwing anything up like i do with home improvements i will just let him do it.
I'm new to the forums so please bare with me. I have a 2010 2SS Auto and want to do and exhaust. I want to put 1-chamber FlowMasters and remove the resonators. By doing so, will this void my warranty? If so, just the cat-back warranty or the entire power-train? I purchased and extended warranty as well.
I dont see how it could include the heads, but I dont know how they could go bad. The dealer will tell you aftermarket valve caps on your tires will void the entire warranty if he thinks you'll believe it.
