2010 Camero Stabilitrak warning
Old Apr 12, 2011 | 09:28 AM
ghostriders's Avatar
Default 2010 Camero Stabilitrak warning
New car an the service stabilitrak light keeps coming on. Is anyone else having this issue and what was done to fix it? Thanks for the help.
Old Apr 12, 2011 | 09:40 AM
moved your thread to the 5th gen section were you should get a little help. welcome to the forum and um read the rules please. thank you and enjoy.
Old Apr 12, 2011 | 02:58 PM
Chevrolet Customer Service's Avatar
Official GM Representitive
Are you looking fix your vehicle yourself or are you willing to work with a dealership?
Jeff Morris, Chevrolet Customer Service
Old Apr 12, 2011 | 05:04 PM
Chevelle Man's Avatar
November 2009 ROTM
2010 Chevrolet Camaro
| Camaro (VIN F) Service Manual | Brakes | Preliminary Information |
Document ID: 2300327
#PIC5204: SES TRAC Stability Indicators Illuminated
Run Rough Or Chuggles - keywords 6.2 6.2L ABS
chafe DTC exhaust harness illumination indicator lamp
light L99 LS3 MIL P0068 P0102 P0107 P0208 P0300 -
(Jul 9, 2009)
Subject: SES TRAC Stability Indicators Illuminated Run Rough or
Chuggles
Models: 2010 Chevrolet Camaro
with V8 Engine (RPO L99 or LS3)
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this
PI.
Condition/Concern:
Some customers may comment that the vehicle will begin to chuggle on accel and one or more
of the following indicators are illuminated... SES, Low Trac and/or Service Stability. When
checking for DTC's, the following may be present; P0068 P0102 P0106 P0107 P0208 P0300
U0237 U2100. This may be caused by a chafed engine harness at the right front exhaust
manifold shield. Depending on which wires are making contact, this may change which DTC set.
Old Apr 13, 2011 | 11:31 AM
I am working with the dealership. Took 2 days to come up with the steering position sensor needs replaced. Is that a norm or could it be wiring as others here are saying
Old Apr 13, 2011 | 06:34 PM
November 2009 ROTM
Let your dealership handle it...what I posted isn't what I'm saying, it's an actual GM bulletin, print it out and bring it to the dealer.
Old Dec 30, 2014 | 03:07 PM
rhiott_SS_ 11211's Avatar
Default stabilitrak issue in 2010 camaro ss
I live in wyoming and my car got stuck in the snow in front of my house. Before we pushed it out I turned the traction control off using the button in the center console. Once I got going and unstuck the service stabilitrack warning came on now my traction control lights are on with the competive mode light as well. Its been -5 and below all week. Is it possible for a sensor or something to have froze up causing the issue. And if not what else could it be. I have unhooked the battery and everything checked plug wires and still nothing. What should I do any thing will help.I have no traction control at all and this makes it very difficult to drive.
Old Dec 30, 2014 | 06:37 PM
might try hitting the area by the brakes with a hair drier to see if it is iced up. don't know anything about 5th gens but i assume thats where the sensors are.
camaroowner27
Nov 13, 2013 11:30 AM
2010CameroSS
2010+ V8 Tech
May 8, 2011 08:15 PM
mopar73
Sep 10, 2009 09:42 PM
Charlene Clark
Jun 14, 2009 04:56 PM
