2010 Camaro SS2 Alternator Upgrade 250A / 0 Gauge Alternator Wiring Upgrade Question?
Old Dec 4, 2016 | 08:45 PM
Camaro_Fuzion's Avatar
Exclamation 2010 Camaro SS2 Alternator Upgrade 250A / 0 Gauge Alternator Wiring Upgrade Question?
I am going to be upgrading my 2010 Chevy Camaro SS2 stock alternator to a 250AMP version. In addition I'll also be upgrading the stock alternator cable to a 0 gauge cable. My questions and concerns are if I will have to run a 20 foot 0 gauge cable from the front all the way to the rear and connect it to the battery in the trunk? GM provided me with a diagram layout of the alternator cable. Does anyone have any experience regarding aftermarket alternators and the proper length of alternator cable best suited for this type of installation? Does the alternator cable have to travel to the engine all the way to the back of the trunk? Is there another proper way to do this upgrade? Will I need any additional parts?
Alternator Cable layout diagram
250 AMP High AMP Alternator Chevy Camaro V8 6.2L 376cid VIN J 2010-2015
20 FT O GAUGE WIRING W/ FUSE KIT
Old Dec 5, 2016 | 07:29 PM
Everett#2390's Avatar
If me, I would run the way GM designed it.
An alternator is only going to output the load sensed.
What are you going to power?
Old Dec 6, 2016 | 02:00 AM
I plan on installing a new stereo with a high end amp with subwoofer. No one still has confirmed on this forum if the car's stock alternator cable is a 1/0 gauge cable. It seems I might not ever get a solid response on here.
Old Dec 6, 2016 | 10:36 AM
Measure the diameter of the present exposed wire and look up wire gauge diameter.
1/0 AWG is generally aftermarket battery cable. 2/0 would be bigger diameter.
Most likely answer for your question is other members probably have not done this option.
COLT45SS
Apr 14, 2012 11:09 PM
belliott
Feb 22, 2012 06:45 PM
otsdarva
Jan 4, 2011 12:31 PM
mkeeler
2010+ V8 Tech
Mar 25, 2010 09:36 PM
Cyrenn
Oct 15, 2009 02:35 PM
