rear end
Old Dec 1, 2006 | 01:32 PM
smurf0781's Avatar
Default rear end
i need info to find out if i take a rear end out of a 96rs will it fit in my 92 rs
and if the brack lines will line up
Old Dec 1, 2006 | 04:38 PM
blackz87's Avatar
Default RE: rear end
First the 4th gen rear will fit. Brake lines lining up is a good question and in most cases no. How the bad news, the 4th gen rear is 4" wider overall, so your wheels & tires will stick out 2" more per side then stock. Also depending on your wheel offsets you may have a problem there also[sm=gears.gif].
Saaampson74
Oct 20, 2008 04:56 PM
libertyforall1776
Nov 10, 2007 03:04 PM
