1980, 305
Old May 24, 2005 | 11:53 PM
AFO's Avatar
AFO
Default 1980, 305
hey, new to camaros and ive got a big problem my gasloline leaks into the oil i have changed the fule pump and it still seems to leak in there. when ever the car gets started up the fule will go up a lil bit more than the last time. anyone no what is wrong here?
Old Jun 3, 2005 | 07:52 PM
Sidewayz6.0's Avatar
Default RE: 1980, 305
I guess I'm not following here. If the gas is leaking into the oil...Which I'm not positive how thats possible, but why would the fuel be going up? If it's leaking out?
Old Jun 6, 2005 | 07:31 PM
azsoprano2's Avatar
Unless the new fuel pump is defective, the only other way is if is leaking from the carb into the intake and so on.
Check your fueil pump again...
Old Aug 11, 2005 | 11:42 PM
nj02z28ls1's Avatar
that might be coolant from a bad head gasket, all my years with cars i never heard about gas in the oil, but you never know.....good luck
Old Aug 12, 2005 | 06:03 PM
aaronsirocz's Avatar
yes, definately check out the head gaskets, that would cause that prob.
1-speed
Oct 9, 2012 07:37 PM
old timer
Aug 18, 2011 06:57 PM
jessica'scamaro
May 25, 2011 01:17 AM
1980Z28RustBucket
Jul 6, 2010 10:43 PM
Jose20
Dec 9, 2009 11:00 PM
