Sub Kill Switch
Old Sep 24, 2006 | 03:29 PM
Celticsfan's Avatar
Default Sub Kill Switch
All i have 2 subs hooked up from when i bought the car, have an clarion amp and jvc headunit, ive tried to get rid of the bass but it just doesnt work, right now there unhooked but i would to have the bass just not all the time, is there anyway i can make on/off or kill switch for them?
Thanks
Old Sep 24, 2006 | 08:12 PM
Slayer's Avatar
Default RE: Sub Kill Switch
On your CD player, do you have an ATT button that will kill the boost? If not just go to your amp, theres a bass boost button( some you can twist with your hand, some you need screwdriver or allen wrenches) just turn the boost down or even off. It's simple and it won't take you but two seconds.
Old Sep 25, 2006 | 12:13 AM
Celticsfan's Avatar
yeah the ATT button on mine just makes it quite, havent tried messing with the amp, but the thing is i want the bass for some music just not all the time...
Old Sep 25, 2006 | 01:54 AM
Slayer's Avatar
Well make up your mind before you drive, if you want the bass or not. if you want it turn the boost up if you dont turnit down. sorry i dont go as far as making personal switches in electronics, but hopefully this might get ya by.
Old Sep 25, 2006 | 06:03 PM
PurpleStangEater's Avatar
or just buy a bass *** for your amp if its clarion they should sell them then you wire it from the amp to where ever you want in the dash and when you want bass twist it all the way up if you only want a lil twist it half way if you want no bass twist it to zero very easy and you wont look like an idiot while turning down the amp in a parking lot lol
Old Sep 25, 2006 | 06:36 PM
Celticsfan's Avatar
Exactly! Good thinking Thanks
Old Sep 25, 2006 | 06:41 PM
no problem bro just didnt want you to have to keep a screw driver in the back so you can adjust your bass every other song haha
Old Sep 26, 2006 | 08:25 PM
chadimus06's Avatar
this is a simple job. there should be a remote wire on your amp (usually blue). it runs to your headunit or to your fuse box. i ran mine to the fuse box. whereever its ran buy a toggle switch and run the wire to it and then to your amp. ive got six 12's and i needed one for tha cops cuz they hate my system. ive got the loudest system in county right now.
Old Sep 28, 2006 | 02:11 PM
Matt99camaro's Avatar
ORIGINAL: chadimus06
What do you hit on a db meter?
Old Oct 8, 2006 | 07:39 PM
bill12690's Avatar
I think this would be a good way to go, and it really isnt very hard.. The whole time I was reading this, I figured "just use a toggle switch" but was thinking of what tire to hook it up to.. until i read that i completely forgot about the remote wire.. sounds like a good plan.. Should be simple and nothing bad about it..not to mention cheap.. just pick up a toggle switch that you like at radioshack or something and there u go.. good thinking chadimus.
