Having Problems at Start-up
Old May 14, 2005 | 10:12 PM
shock6906's Avatar
Default Having Problems at Start-up
I'm having problems with my camaro at start up. I have a 97 Z-28. The problem that I'm having is that when I try to crank the car on a cold engine, it will roll over but won't actually crank. I have found that if I bump the ignition a couple times, it will eventually crank. The thing is, it doesn't do it when the engine is up to temperature. (such as when I drive somewhere and start back up before the engine cools off. I have already replaced the crankshaft sensor, what do you think the problem may be? Thanks for your help, Alan.
thez28beast317
Sep 5, 2011 03:42 PM
Sanman
Feb 5, 2010 09:46 AM
lt1_performance
Dec 12, 2009 04:13 AM
tipdrip215
Nov 30, 2009 03:38 PM
ama323
Sep 15, 2005 03:52 PM
