weird noise
Old Sep 6, 2006 | 11:11 PM
davidalvarez82@hotma's Avatar
Default weird noise
every time go around a curve to the left i hear this grinding sound and its coming from the driverside rear wheel so i though it might be wheel drag thats when the calipers are not adjusted right or the rotar might be warped so i took it to the dealer to have it checked out and they did not find anything wrong does anyone know what it could be? P.S. i have a 2000 ss if that helps thanks
Old Sep 14, 2006 | 04:26 PM
1969 SS's Avatar
Default RE: weird noise
bad wheel bearing?
Old Sep 14, 2006 | 09:52 PM
thanks
Old Sep 16, 2006 | 06:43 PM
1969 SS's Avatar
any results yet?
Old Sep 16, 2006 | 07:47 PM
no not yet havent had time to take it in to the shop.
Old Sep 21, 2006 | 11:55 AM
Blade's Avatar
June 2007 ROTM
does the wheel stop moving, if so u might have a spool in the rear for racing.
Old Sep 21, 2006 | 12:14 PM
1969 SS's Avatar
usually spools sound link a clunk becuase they skip instead of roll around corners, but I just though of something else. jack up your rear tire and try to lift it up and down by hand. if you can do that without the rearend moving, you have a bad outer bearing in your rearend. if I listen closely it sounds like a slight bang, but most people are always describing it as a grinding noise.
longshot but just another online diagnosis[X(]
Old Sep 21, 2006 | 08:41 PM
thanks guys for the input I'll try lifting up the rear and see what happens.
Old Oct 19, 2006 | 12:55 PM
airchevy02's Avatar
with the car on the lift see if the tire has play in it, either up and down or side to side... i would have to guess though from your post it is the wheel bearing.. good luck
Old Oct 28, 2006 | 03:28 PM
chadimus06's Avatar
the bushings might be bad on the panhard rod.
Murda99v6
Sep 30, 2010 09:56 PM
TEXASMAN1
Jun 12, 2008 04:45 PM
biohazard
Jan 7, 2008 05:47 PM
Saint_Ali
Nov 14, 2007 12:45 PM
Sep 9, 2006 08:45 PM
