monsoon cd deck problem
Old Sep 3, 2006 | 05:17 PM
slowZ's Avatar
Default monsoon cd deck problem
i have a '99 camaro with the monsoon system and everytime i put a cd in it reads ERR (which im assuming means ERROR) then ejects the cd by itself...if anybody has any info as to what the problem could be. i would appreciate and try any opinions you might have ....thanks.....i already tried a cleaning disc (it didnt work)
Old Sep 22, 2006 | 05:35 PM
1969 SS's Avatar
Default RE: monsoon cd deck problem
these are regular CDs you are using and not ones burnt by yourself?
Old Dec 25, 2006 | 08:03 PM
02camarogirl's Avatar
My radio is doing the same thing, I was just wondering if it is possible to get it back working normal? Ive already tried using regular CDs. If anyone can tell me if I completely destroyed it or if will work again. Thanks!
Old Feb 10, 2007 | 08:37 PM
libertyforall1776's Avatar
RTFM! ;-)
Sometimes this happens when the car is very cold -- wait for it to warm up...
From the Owner's Manual:
"Playing a Compact Disc
Insert a disc partway into the slot, label side up. The
player will pull it in. The disc should begin playing. The
display will show CD and the CD symbol. If you want
to insert a compact disc with the ignition off, first press
RECALL or EJECT.
If you’re driving on a very rough road or if it’s very hot,
the disc may not play and ERR (error) may appear on
the display. Press RECALL to take ERR off the display.
When things get back to normal, the disc should play.
If the disc comes out, it could be one of the following:
The disc is upside down.
It is dirty, scratched or wet.
It is very humid. (If so, wait about an hour
and try again.)"
ORIGINAL: slowZ
Old Feb 15, 2007 | 08:03 PM
slowZ's Avatar
i dont think its cause it was cold because i live in florida. it doesnt get very cold here. but i went and got a new head a while ago and i've had no problems with it.
moparmusclecars
Apr 22, 2014 11:34 AM
mikes68
Nov 27, 2011 06:21 PM
auto
Jul 18, 2011 10:51 PM
torque_is_good
Jan 25, 2009 09:18 PM
EddieTheRipper
Oct 29, 2007 07:44 AM
