lights, camera, action...wait...no, forget the lights
Old Sep 7, 2010 | 10:44 PM
Bing's Avatar
Default lights, camera, action...wait...no, forget the lights
So several questions here, but the first being,
On my camaro the left lights (front that is) don't work. They're dim, but the blinker doesn't work nor the head light. Also, the right turn signal is flacky. Any suggestions as to where to start looking?
Second. on this link does anyone know where the reinforcement bar goes? (#9).
Old Sep 8, 2010 | 12:10 PM
Bing's Avatar
oh yes, and to add to those questions.
...and this one makes me feel real dumb, but how do i change the oil? I can't find anywhere to add the oil... is it under one of the valve covers?
Also, changing out the radiator fluid...is their a quick way to drain it?
Old Sep 8, 2010 | 04:56 PM
80ZJoe's Avatar
July 2010 ROTM
Yeah, you pour the oil into the valve cover, i put it in where the cleaner/breather is. And on the rad, there should be a drain hole at the bottom. For the lights i would just start with new bulbs first.
Joe
Old Sep 8, 2010 | 06:11 PM
Check for voltage at the sockets! Often the issues you're having are related to bad grounds. If you read the socket voltage to ground and it's not 12 v. then read it from the socket to the battery - post.
Old Sep 8, 2010 | 06:43 PM
Did someone punch it in the eye?
Old Sep 9, 2010 | 12:39 PM
Bing's Avatar
Seriously, not b-sing me about pouring it into the value cover (where the breather is?).
I think your right about the ground, i'll go and check that.
No, no one punched it in the eye...the off roading trip prob didn't help though.
Old Sep 9, 2010 | 06:28 PM
LOL def a ground then and yeah pour it in the valve cover.
Old Sep 9, 2010 | 07:58 PM
lynchingacers's Avatar
you could always just throw on a good solid new ground on each side so you're guaranteed that they have good ground then...
on mine i had to replace the socket on the right side because a tree dripped leaves and water on that side and the socket had lots all the internal connections in a pile of rust
bought a new one a t the auto parts store( 1157 ) and replaced it using quick disconnects
Old Sep 20, 2010 | 08:09 AM
Blue Bandit's Avatar
Yep, into the valve cover, confused me a little when I got my first American car (Trans Am) and spent 15 minutes trying to find the oil filler on it !!
pojo1988
Aug 27, 2017 09:35 PM
98Z28ImportSlayer
Mar 16, 2012 09:07 AM
vXIcetreyXv
Oct 23, 2009 07:25 PM
bodykits
Jul 1, 2009 09:52 PM
91 RS
Feb 24, 2007 11:14 PM
