compression
Old Sep 7, 2010 | 10:22 PM
BasicConcepts's Avatar
Default compression
so i finally got around to picking up a compression gauge and this is what i came up with
cyl 1 - 185psi
cyl 2 - 185psi
cyl 3 - 185psi
cyl 4 - 165psi
cyl 5 - 175psi
cyl 6 - 165psi
sounds good???
btw i dont understand why everyone btches about the plugs they were easy try doing plugs on a fwd 4.0 V8 northstar motor thats a btch
Old Sep 8, 2010 | 09:36 AM
Compression is good.
Old Sep 8, 2010 | 10:37 AM
1augapfel's Avatar
The Haynes manual says that the minimum compression pressure is 100 psi and the max variation between cylinders (highest to lowest) is 30%.
Based on that I'd say your 3.4 is in very good condition.
Old Sep 8, 2010 | 11:08 AM
I had a guy complain to me one time about how hard the plugs where to get to in his 67 impala with a 327 cause it had headers on it. It is all relative. It is a pain if you do not own a swivel. LOL
Old Sep 8, 2010 | 11:13 AM
KissMyTush's Avatar
They aren't that hard on the V6s. What the ***** is, with a V8! It is a major pain in the ***!
Old Sep 8, 2010 | 02:49 PM
Vandee's Avatar
3.8l without a swivel sucks.....but like you said its all relative to what pina means to you
Old Sep 9, 2010 | 01:30 AM
RFxCamaro's Avatar
3.8 is a pain lt1 was actually easier
Old Sep 9, 2010 | 03:02 PM
KissMyTush's Avatar
By V8 I meant LS1.
Old Sep 10, 2010 | 12:49 AM
jurmy2's Avatar
Ive had an RS and own a Z28 now. The plugs on the v6 are just ridiculous, the z doesn't get me throwing tools after you've been working on that ONE plug for 15 mins.
Old Sep 10, 2010 | 08:04 PM
must be the 3.8 cuz the 3.4 is eeeeaaaasssssyyyyyy i didnt even need a swivel
