1974 Type LT exhaust question. PLZ HELP!
Old Sep 7, 2010 | 04:52 PM
Jeromaro's Avatar
Default 1974 Type LT exhaust question. PLZ HELP!
So I'm selling my 95, and considering a '74. I noticed that the 350 74 LT this guy was trying to sell me didn't have dual exhaust. I asked about it he said only the '74 z28 had dual. That ain't right is it?
No v8 can have single exhuast right? . . .
Is this true?
Old Sep 7, 2010 | 06:28 PM
80ZJoe's Avatar
July 2010 ROTM
Well i wasnt 100% sure so I checked it out and this is a description i copied from the 74 data, but this is from the special performance package.
Engine: Includes special 350 CID, 245 hp V8. Four-bolt main bearing caps, forged steel crank, impact extruded aluminum pistons, heat treated & shot peened connecting rods "big valve" cylinder heads with high speed valve train. Cast aluminum rocker covers with internal galleries. Hydraulic lifters cam & cast iron intake with EGR. Rochester Quadrajet. 17-quart cooling system with 18" 7 blade flex fan. Oil pan windage tray and high speed crankshaft damper. Dual Exhaust pipe system. Same setup as 1973, HEI (high-energy ignition) introduced in mid-year (January 74). Special dual snorkle air cleaner with chrome lid.
here is the link where i found it
http://www.nastyz28.com/camaro/camaro74.php
But i would beleive the 350's came with dual exhaust but im still not 100% sure sorry
Joe
Old Sep 7, 2010 | 07:46 PM
In 75 they started putting cats under there. So yes, manifolds, y pipe, converter, single in duel out muffler. That is possible.
Fire Chief
May 23, 2011 10:42 AM
Phalen123
Mar 25, 2011 12:08 AM
NYH1
Dec 12, 2010 01:50 PM
zokkoz17
May 12, 2010 07:12 AM
94 Z28 B4C
Aug 12, 2006 07:09 PM
