194 heads?
Old Sep 5, 2010 | 08:04 PM
mainejohn's Avatar
Default 194 heads?
i just looked at the build sheet for my camaro and the motor came from s+s motors. it says it has 194 intake heads, flat top pistons, performance cam(?) flat lifters, 4 bolt main. not sure of the cam, and don't know much about those heads!! any advice about swapping out those heads.
Old Sep 5, 2010 | 08:07 PM
Vortecs, the best bag for your buck. Less than 500 bills.
Old Sep 5, 2010 | 08:23 PM
mainejohn's Avatar
vortec heads? so vortec heads will bolt up fine to my old school 350? it has a elderbrock proformer intake and 650 holey.
Old Sep 5, 2010 | 08:34 PM
You'll need a intake, sorry I forgot.
Old Sep 5, 2010 | 09:01 PM
The way that's worded (since the intake is specified), can easily refer to having 1.94" intake valves. Not necessarily Vortec heads. You might want to remove a valve cover, find the casting number on top of the head, and lookemup.
Old Sep 6, 2010 | 04:54 AM
mainejohn's Avatar
okay will do
Old Sep 6, 2010 | 05:58 PM
Packfan88's Avatar
Same casting number on both?
Or is it like an A & B for lerft and right or L & R or either head can go on either side of the engine?
Im gonna pull a cover tomorrow and see whats what under there.
Old Sep 6, 2010 | 06:10 PM
Heads go on either side.
Old Sep 6, 2010 | 06:24 PM
Yes same casting number for both sides. You would need to be concerned about a left and right fitment if there are accessory mounting holes only on one end of the head.
Old Sep 6, 2010 | 07:11 PM
If you have 1.94 heads I wouldn't spend the money to upgrade to Vortec heads. They are better, but not enough so to justify spending the extra $500 if it were me.
