88 iroc z engine suggestions?
Old Sep 1, 2010 | 08:23 PM
big greg's Avatar
Default 88 iroc z engine suggestions?
my car is an 88, but the engine is out of a 91, i believe it had the 305 tpi, but now is the 350 tpi, it runs great and all, but i want more, my question is, will a 400 from a 70ish caprice be a good build? will the tpi intake bolt up to the 400 small block? can i tune the computer to feed more fuel that will be needed? thanks in advance
Old Sep 1, 2010 | 08:24 PM
big greg's Avatar
forgot to mention it is coupled to a t5 and a 411 eaton posi, headers and a full 3" exhaust, will the bell housing bolt up?
Old Sep 1, 2010 | 08:35 PM
djs383's Avatar
I don't know for a fact about either the intake, or the T5, someone else will know for sure, but I'm not sure how you are going to get around the knock sensor required for the computer controller distributor......
Old Sep 1, 2010 | 08:42 PM
big greg's Avatar
hmm, maybe just punch it over with a big cam and heads?
Old Sep 2, 2010 | 08:48 PM
microkid's Avatar
March 2011 ROTM
anything more and that poor t-5 will explode. but if you want to test it, get some aluminum heads with a small chamber size to up the compression and get a bigger cam
Old Sep 3, 2010 | 04:32 PM
big greg's Avatar
ha im willing to test out this trans, i heard they do not like power very much
Old Sep 3, 2010 | 05:09 PM
microkid's Avatar
March 2011 ROTM
anything more than a mild 350 and it will start separating, even with careful shifting and no burnouts. but if you happen upon a spare or want a reason to buy a better trans, go for it
Old Sep 9, 2010 | 11:01 AM
big greg's Avatar
so what has to be done to the t56 to get it in there? i heard something about the bell housing?
Old Sep 9, 2010 | 07:25 PM
big greg's Avatar
anybody know a good prom chip maker? im goin to have to get one flashed if i put this big cam in her
barkysan
Mar 23, 2011 04:43 PM
JNap936
May 29, 2007 09:24 PM
Deezil13
Oct 12, 2006 08:00 PM
Withered962
Jul 26, 2006 10:26 AM
MoreLikePALcohol
May 21, 2006 02:28 PM
