5.7 tpi to a lt-1
Old Aug 31, 2010 | 05:59 PM
128averi's Avatar
Default 5.7 tpi to a lt-1
will a lt-1 motor from a 1994 pontic firebird work in a 1989 camaro.if so what changes will i have to make. i also have the transmission with the lt-1.
thanks alot
Old Aug 31, 2010 | 06:51 PM
Caveman305's Avatar
Shouldnt need anything but the wiring and computer unless you have a tuning set up, other than that if you plan on running ac ive heard of having to relocate the compressor due to clearance issues, maybe a crossmember for the tranny or modify the one u have
Old Aug 31, 2010 | 07:36 PM
microkid's Avatar
March 2011 ROTM
you will need aftermarket gauges for tach, oil pressure, temps, and whatever else you may need. your speedo should be cable driven and wont need to be replaced as well. you could repin the wiring harness and redo it to use the factory gauges, but its faster and cheaper to run aftermarket. as for the physical fit, it is a direct bolt in. you may have to make some coolant hoses to plumb it as well as fuel lines, and the entire ecm and wiring from the lt1 donor. that should be most of the major things
Old Aug 31, 2010 | 10:31 PM
Caveman305's Avatar
Good catch micro, i forgot about gauges
Old Sep 2, 2010 | 08:42 PM
microkid's Avatar
March 2011 ROTM
its not impossible to do. someone had a car in camaro performers, it was originally an lt1 and they swapped over the front end and i think an ls1 or ls2 and used the factory gauges
