When a car's heating system is turned on, is it likely to consume more fuel ?
Old Aug 31, 2010 | 06:49 AM
brightbill's Avatar
Default When a car's heating system is turned on, is it likely to consume more fuel ?
An air conditioner's compressor causes the engine to run at higher rpm. But the same may not be true in heating. In fact, I think it is merely the engine's exhaust heat that is diverted to heat the air inside the cabin. Is that true?
Old Aug 31, 2010 | 08:40 AM
no the engine coolant is run through the heater core (small radiator) and the fan forses air through it for the heat. when i turn on the defrost the a/c pump comes on on mine so mpg is affected when the defrost is on.
Old Aug 31, 2010 | 11:43 AM
Only those who want to commit suicide will route exhaust into the cabin. For most people that I know, I don't recommend that
Seriously though, the old air cooled VW's, Corvairs, and Porsche's routed radiant exhaust heat into the cabin (they used special heater box/head pipes. The heating system in them kinda sucked, at best. Water cooled cars use a heater core. The heating system isn't going to make the engine consume more fuel, unless you have defrost on which does run the A/C along with the heat (as craby said) to dehumidify the cabin.
paris0145
Feb 28, 2015 01:53 PM
H2C
Nov 10, 2010 11:41 AM
vogel822
May 27, 2010 02:06 PM
keokabear
Jun 30, 2009 08:30 PM
90iroc-z28
Apr 27, 2009 01:36 PM
