Instrument cluster goes dark??
Old Aug 26, 2010 | 10:34 PM
Bankos66's Avatar
Default Instrument cluster goes dark??
So the instrument cluster goes dark when the headlights are on and the reading lams in the rearview mirror stay on and so does the one in the rear seats. Does anybody know what could be wrong with this? Thanks in advance. Also where is the Fuse Box located?
Old Aug 26, 2010 | 11:54 PM
theres a fuse box on the driver side of the dash by the door hinge. you have to open the door to see or access it. theres one under the hood, under a cover on the driver side wheel wheel. what yr you have,
Old Aug 27, 2010 | 05:40 PM
Bankos66's Avatar
i have a 99
Old Aug 27, 2010 | 05:54 PM
osduck5's Avatar
Possible head lamp switch going bad?
Old Aug 31, 2010 | 09:48 AM
Bankos66's Avatar
Somebody told me it could be a bad bulb
Old Aug 31, 2010 | 10:29 AM
you said they go dark when the headlights are turned on. does that mean they are on and then go off or they dont work at all?
Old Sep 2, 2010 | 09:49 PM
Bankos66's Avatar
They don't work at all. The odometer dims and the radio lights turn off.
Old Sep 2, 2010 | 10:06 PM
Bankos66's Avatar
thank u
Old Sep 2, 2010 | 10:33 PM
BasicConcepts's Avatar
i had the same problem theres a fuse that says gauges on the driverside of the dash its a 5 amp it thats not blown its the dimmer switch (the dial you dim the dashlight and radio with) most likely the fuse tho
Old Sep 3, 2010 | 02:22 PM
Bankos66's Avatar
I already checked the fuse. It must be the dimmer switch than. thank u
