bone stock dyno today
Old Jul 20, 2010 | 10:19 PM
Adam_muz's Avatar
Default bone stock dyno today
Hello everyone i got my car dynoed today has a bone stock Ls1.. i have a 2000 camaro ss.. the car made 286whp and 318 torque.. i wanna know if this is an average number?
Old Jul 21, 2010 | 03:20 PM
maudyZ28's Avatar
yeah thats pretty good dude, specially at the wheels. You auto or manual?? what type of dyno?
I wouldn't get too hooked up on dyno numbers, they all vary
best test is your 1/4 mile time
Old Jul 21, 2010 | 04:54 PM
libertyforall1776's Avatar
MotorTrend dyno'd a stock 2002 SS, but their #s seem low, since a stock 2001+ should be higher than your 2000 (with the cam change and LS6 intake starting in 2001)...
Max hp/rpm 268.4/4400
Max torque/rpm 280.8/4200
http://www.motortrend.com/roadtests/...ang_specs.html
Old Jul 22, 2010 | 07:15 PM
KissMyTush's Avatar
Werd! I still haven't had the chance to run mine yet!
Old Jul 22, 2010 | 08:30 PM
Depending on your drive train, that equates to be between 336-357 h.p. at the crank. Crankshaft h.p. is how the factory rates engines.
So...not too shabby!
Old Jul 23, 2010 | 02:19 AM
Adam_muz's Avatar
i dyoned it on a Dynojet. and i have a t-56 6speed.. the guy was telling me i should get a tune with the hp tuners... is this a normal tuning device for the ls1 f-bodies? i just put the airbox lid from SLP maybe the numbers might be higher now =) oh and btw the guy also was telling me i was pinging and im running very lean? idk if this is normal for being stock!?
Old Jul 23, 2010 | 11:56 AM
KissMyTush's Avatar
Hp Tuners is the best tuning quality you can get for your money! It's easy and you can do anything with it! I'm saving up some money for it right now!
Old Jul 24, 2010 | 12:13 PM
cbr600rx7's Avatar
Motortrend is also the devil. I wouldn't listen to any thing they report what so ever. With that being said that's probably the lowest dyno i have ever seen from any LS1 engine by a lot. The average T56 LS1 will dyno right around 290-300 at the rear wheels bone stock and should be around 310 torque. Even A4 guys will normally dyno 285 plus with no problems. Also peak horsepower should be made well over 5200 RPM's not at 4400 so that raises a question right there. Plus i would expect peak torque to be made much lower as well. But hey what do i know.
It sounds like your O2 or MAF may be on its way out if you are running lean on a stock car. I am betting if you figure out which one is giving you problems and replace it you would have probably seen closs to 300 at the wheels.
Old Jul 24, 2010 | 07:49 PM
KissMyTush's Avatar
Yeah what he^ Said! Lol!
Old Jul 25, 2010 | 12:13 PM
cbr600rx7's Avatar
Bone stock 4L60 1999 vette with around 100K.
If you look at the dyno you will see peak torque is made at around 3300 and peak horse power is much hits right around 5300 way off from what motortrend reported. I dont know what motortrend was dynoing but something sounds funny.
