mono vs. leaf
Old Mar 31, 2005 | 11:43 PM
olynciw's Avatar
Default mono vs. leaf
I am a corvette guy and have my 1st camaro 67 to be exact. I have run both mono and oem leaf my cars. What is the best anyone has found to work better on the camaro? The car is pushing approx. 375hp to the rear wheels.
Old Apr 1, 2005 | 05:39 PM
Patrick's Avatar
Administrator
Default RE: mono vs. leaf
can you go with a coilover setup?
i ran Super stocks on my 83...
Old Apr 29, 2005 | 08:59 PM
carnutt94's Avatar
IMO that's persomal opinion, most will prefer mono for drag...lighter and car will squat easier on rear (weight transfer)...i personally had multi on my 67 with vented air shocks and traction bars...B/B turbo 400 ...launched pretty good...Allan....also vette ovner...1968
Old Apr 30, 2005 | 03:25 PM
Patrick's Avatar
Administrator
hmm..but also with a mono...with a good solid bite, youre more likely to flip one...and that can get ugly.
Old May 4, 2005 | 12:05 AM
68RS CRAZY's Avatar
I have a 68 rs with aout 490 hp .PG trans with transbreak and 3400 stall I am running mono with traction bars and air shocks at about 10 to 20 pounds PSI. No problems yet but I have just played around with it .No track time yet.
Old May 4, 2005 | 10:33 PM
Patrick's Avatar
Administrator
i watched a gorgeous 70 hemicuda with huge slicks and monos with DOTs stomp it in a garage and flip one..and tear the fender up...[:@]
Old May 16, 2005 | 05:36 AM
Mr_Chu's Avatar
Hey i just bought some hotchkis leaf springs for my 68 camaro... I bought Multi-leaf but my camaro is mono-leaf. Do i have to buy the brackets to go from Mono to Multi??
If so what else do i need to buy?
Old Jun 23, 2005 | 03:52 AM
68maro's Avatar
monoleafs are usually installed on 67's and 6 cyl 68's. They were replaced because of wheel hop in high horsepower cars
Old Aug 18, 2005 | 11:50 PM
Got to watch you rear end setup when you are making real power. Te right side torques up, the right rear corner drops down and the whole car might just flip. When Chrysler was big on super stock racing, they had to use leaf springs, so they solved the problem by shifting the axle way to the front of the springs, which helped weight distribution, and the short front end of the springs was stiff enough to act as a traction bar. They also added leaves to the right the rear spring making it stiff enough to keep the car rear level at launch. These cars would launch with the front wheels about 2 in off the ground and hold them there almost half way down the strip. It took Chevy a few months to figure this set up out and catch up. They also used snubbers on top of the pinon so that the body would sit down on it and further help to keep the wheels from hopping.
CaCruiser
Oct 25, 2014 08:27 AM
nasty50
67-69 V8 Tech
Oct 20, 2011 06:18 PM
kudnu89
Jan 22, 2011 06:08 PM
L Holmes
Oct 3, 2009 08:02 PM
jenz
Jun 21, 2008 01:00 PM
