3.1 V6--- 350
Old Mar 21, 2005 | 08:48 PM
WillBFastCamaro91's Avatar
Default 3.1 V6--- 350
Hey I just aquired a 91 camaro RS 3.1 (3.1 V6? is that correct) well anyway if it is its also manual.I have a 350... will it bolt up to the tranny? I have the motor mounts, will I need to change anything as far as tranny wise or anything else? Just remember I am just getting started so be easy!!!!!
Old Mar 22, 2005 | 09:23 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
Default RE: 3.1 V6--- 350
well its hard enough to swap a 350 into a 305 car witha manual, so id imagine it would be rediculously hard to do a 3.1 to a 350. you would have to change all the mounts, the computer, and probably the trans, as wellas the driveshaft
Old Apr 28, 2005 | 11:08 PM
YoungGun_Mechanic's Avatar
Yes that is a 3.1 in your camaro. I don't remeber the exact year, but I believe it was 1990 when they switched the camaro from a 2.8 to the 3.1 for more power. Actually its the same motor, *60 degree V6, just bored out etc. Well I think I have some good news for you actually. I have been told that it is a T-5 Transmission in your car. Do you know what that means? Its the same damn tranny that is in the 305/350 camaros. At least I believe it didn't change because I know the 88's had that transmission. Well anyways it should be the same! So, that means, change your engine mounts to the V8, slap on a carb, rip out all your EFI junk, upgrade your suspension in the front (not 100% needed, but definately recommended) and your set! Have fun with your beast, and I expect to see pictures!
EDIT;
SEE THIS THREAD https://camaroforums.com/m_252/tm.htm
A guy said his transmission had a different pattern. I would suggest looking what kind of transmission you have just to be sure......
Old Apr 28, 2005 | 11:12 PM
ORIGINAL: nj85z28
Whats so hard with putting a 350 into your car? Its a sbc, and yours is a sbc... Just need to switch to a carb set up and get rid of your fuel injection... Maybe a few extras like running your 305 accessories, but I don't see the big deal? Just some fuel lines and a carb. Unless there is something I don't know about these cars.. No difference with an automatic or a manual... I guess it all depends on your backround ..
Old Apr 29, 2005 | 06:33 PM
nj85z28's Avatar
February 2012 ROTM
May 2012 ROTM
ORIGINAL: YoungGun_Mechanic
ORIGINAL: nj85z28
Actually, background has nothing to do with it. Last summers project was to put a 350 into an 86 TA witha 5 speed. The problem was the Borg Warner tranny needed a million extra parts to make it work. everything from the crankshaft to the clutchplates was different. might have only been a problem with this particular swap, but in general i would say it was pretty difficult, especially with all the mixmatched parts from 4th gens to make the clutch and pressure plate bolt up.
Old Jun 29, 2005 | 12:22 AM
mattvogt's Avatar
Just sell your car and buy what you want. dont MESS with switching the engine.
Have fun w/ it though
MODERATOR'S NOTE--- WATCH THE LANGUAGE IN THESE FORUMS OR I WILL HAVE TO REPORT IT TO MY HIGHER UPS!~ NJ85Z28
