Help!
Old Nov 21, 2009 | 10:43 AM
Lilspleen's Avatar
Default Help!
alright i was out cruising last night and i went to start my car and it died. it would crank over and start but it would get to 1400 rpm and then they would fall and die. i checked the battery and i had 1/2 a tank of gas. any advice is appreciated thanks
Old Nov 21, 2009 | 10:46 AM
Toneman07's Avatar
Alternator or you blew a vacuum line somewhere but itd be a major one.... also check your fuel pressure on the line
what year is ur car
Old Nov 21, 2009 | 10:53 AM
Lilspleen's Avatar
its a 98 and itll start just fine but it dies after like 10seconds
Old Nov 21, 2009 | 11:09 AM
Toneman07's Avatar
ahhh ok then you need to check fuel pressure and listen under hood do you hear a huge vacuum leak? run the car for any codes car doesnt need to be running to do this
Old Nov 21, 2009 | 04:28 PM
Lilspleen's Avatar
it works now, me and my brother looked at it and it started up like nothing happened
Old Nov 21, 2009 | 05:00 PM
Guess it just needed a good "looking at"!
Seriously though, if it happened once, it can happen again, Cars generally aren't self-healing.
Old Nov 21, 2009 | 05:15 PM
Toneman07's Avatar
for real wish my car would fix itself
