2 Much Virbrating???
Old Nov 19, 2009 | 11:41 PM
carpenterkyle's Avatar
Question 2 Much Virbrating???
I switched engines and had to mess with the timing to get the 2.8L now in my 1992 camaro to fire up. The engine came out of a 84 camaro it's firing up fine but it's virbrating the whole car more than it should be...suggestions? Also kept ALL the wiring harness, pullies, & accessories off the 3.1 & put them on the 2.8
Old Nov 20, 2009 | 01:25 AM
sewerrat's Avatar
Are you using the 3.1 flywheel onto the 84 2.8? If you did then you may have the same problem I ran into several years ago on my engine swap. The 3.1 uses a neutral balance flywheel or flexplate but the 84 is external balance. 87 and up engines have a big counter weight built into the crankshaft while the earlier years had the weight on the flywheel. HTH
Old Nov 20, 2009 | 02:13 PM
yeah im using the flywheel from the 3.1 on the 2.8 also took the harmonic balancer off 3.1 & put on 2.8, u think maybe it could be the timing is a little off too cuz i don't know much bout the timing i just know it was 180 degrees off when i took the cap off when i fixed that it fired right up...what can i do about this?
Old Nov 20, 2009 | 05:40 PM
May want to check the plug wires are not crossed. That will give you a really nice vibration.
