1989 camaro wont start
Old Nov 19, 2009 | 06:11 PM
myles's Avatar
Default 1989 camaro wont start
well just got a new battey because the other one went bad. well it was running Ok for a while. until the last 3 days. needed jumped everywhere i went (which got really old) so went and got the alt checked. working fine. so i get a new battery, now when i turn the key my temp gauge either goes all the way up and wont turn over or everything just turns off completley, i close my door then open it and i have power again. i mean like fuel pump and everything looses power. so i hooked up my code reader and i got, "Diagnostic mode; no distributor signal to Electronic Control Module; System PASS"
any one got any ideas??? this is my dd by the way. has 47,859 original miles and its a fuel injected 2.8 v6
Old Nov 19, 2009 | 07:19 PM
microkid's Avatar
March 2011 ROTM
inspect the chassis ground, battery postive and alternator wires for loose connections, corrosion, or any signs of damage. it sounds like it could just be a bad wire. also check the wiring going to and at the fuse block for the same problems.
Old Nov 20, 2009 | 02:18 PM
The Firebird Lady's Avatar
From: Michigan for now but will move back to Rhode Island soon
I would check the wires on the battery and make sure the posts are clean but I would do one other thing. This sounds alot like an issue I had with a Berlinetta I owned. Check the wire the runs into the back of the alternator. Mine was breaking off and thus losing connection to the alternator which keeps your battery charged. It could be that simple. You said you also got a distributor code? When was the last time the cap or distributor itself was changed? Could be that.
Old Nov 20, 2009 | 02:42 PM
need to look for ground studs or screws along the bottom of the dash and the steering column. also should be a ground junction under the kick pads. clean and tighten any u find.
Old Nov 21, 2009 | 01:54 PM
myles's Avatar
ok well i checked and cleaned grounds, conections ect that needed it. it attemped to turn over then quit and doing the same thing. but now if i turn my headlights on i loose all power to everything then i close and open my door im geting power again.
Old Nov 22, 2009 | 07:27 PM
microkid's Avatar
March 2011 ROTM
does it have any sort of antitheft? i know the 1990 started with the vats, im not sure if it may have been brought on late 89. or it might be possible someone added something to it at sometime, and it has since failed. most of them disable the ignition, which could cause the code.
Old Nov 23, 2009 | 10:04 AM
myles's Avatar
im not sure. the security light comes on. never knotest if it has before. but we just put in a new ignition like 3 months ago cuz the chip in my last key went bad, so we got a whole new ignition.
Old Nov 23, 2009 | 07:11 PM
microkid's Avatar
March 2011 ROTM
that might be the problem then. i dont know why the door closing would change it, but im betting there is something wrong with the replacement. there is a write up somewhere on this site about disabling the vats. you could try doing that and see if it stops your problem
tfortney
Jan 14, 2013 01:57 PM
Tuffdrvr88
Nov 28, 2011 08:56 AM
korben dallas
Feb 25, 2011 05:46 PM
neversave
82-92 V6 Tech
Feb 4, 2009 11:59 PM
Joe7583
Jul 16, 2006 11:29 PM
