ANYBODY know were to get rear differential cover??
Old Nov 16, 2009 | 08:03 PM
ROWDYROB's Avatar
Default ANYBODY know were to get rear differential cover??
to be more specific--one of those cast aluminum ones to fit a 10bolt 77 camaro--i can find the cheap chrome ones everywere,but those just rust up in no time---thanks
Old Nov 16, 2009 | 09:09 PM
Old Nov 17, 2009 | 08:16 PM
ROWDYROB's Avatar
hey--i did look at summit before,but i absolutely cant remember if the 77 with 10 bolt has the 7.5 or 8.5 gear---thanks
Old Nov 18, 2009 | 06:51 PM
Not sure either, but if you pull the cover you can measure. Or you can look and see if the cast housing has the square ears on the bottom edge by the cover. If it has the two square ears that show from behind, then it's an 8.5"
If you look at this old picture you can see the little ears at the bottom edge of each side.
My rearend is from a 79 Trans Am, but I think the 77 Camaro was also a 8.5".
Old Nov 18, 2009 | 08:04 PM
ROWDYROB's Avatar
yes it does--thanks
Camaro3800V6
Feb 11, 2015 08:00 PM
Gorn
Jan 18, 2013 11:09 PM
pobasturd
Oct 11, 2012 09:36 AM
Toneman07
Oct 16, 2009 01:47 PM
JaySan
Apr 6, 2007 01:03 AM
