Top Speed
Old Nov 16, 2009 | 05:56 PM
JeepGuy12's Avatar
Default Top Speed
Does anyone know how fast the 99 3.8l manual transmission camaro can go? Thanks
Old Nov 16, 2009 | 06:12 PM
blackz87's Avatar
Speed limited by Factory to 110 MPH, if you can get it up to that. The speed limiting is due to the Non-speed rated tires in most stock cases was H-rated.
Old Nov 16, 2009 | 06:44 PM
DavidJ1907's Avatar
I've got a 99 4spd automatic, and I know I've seen my speedo at 115. Unless theres a difference between a manual and automatic in that department, or I don't have a limiter on my car.
Old Nov 16, 2009 | 06:57 PM
Cammy 3.8lV6's Avatar
My automatic 2000 camaro 3.8 has hit the 125mph , i actually only hit 122mph and slowed down because of a distant corner but my gf actually hit the 125 on a straightaway and said it felt like it was still climbing !
I kinda fail to see the point of hitting such speeds though, I haven't tried to hit that mark since that one time, probly cuz it's 55mph all throughout Upper Michigan lol!
Old Nov 16, 2009 | 07:24 PM
cbr600rx7's Avatar
Back in the day i had my 2.8 above 115, mind you that took about 2 miles of strait road. I have also had my old 3.8 A4 Y87 car well into the 115-120 range the only mods where a wisper lid with K&N filter and a cat back exhaust. I fill like the car still had a little more to go
Old Nov 17, 2009 | 03:18 AM
evilkal's Avatar
99 A4 here... Our cars are governed at 120 unless you have it removed. I can hit 125 at about 3 grand. I can bury the speedo before I hit 4. But I've got quite a few mods. Even a stock car would push the 125 range though. I'd guess around 130.
Old Nov 17, 2009 | 07:41 AM
x01660's Avatar
The Mustang Hunter
I have a 95 3.4L A4 with a homemade CAI, and I topped out at 136, measured with a gps accurate to 6 feet.
Old Nov 17, 2009 | 12:31 PM
Jonny Dubyah's Avatar
Yea mine is limited to 120..it makes it there with no problem though..how does one go about removing the limiter?
Old Nov 17, 2009 | 12:40 PM
evilkal's Avatar
I don't buy that you hit 136 in a 3.4... Basically stock at that.
But you have to get it tuned out of your PCM Jonny.
Old Nov 17, 2009 | 04:33 PM
Ahh..thats what i figured..will they do that if you get it tuned through pcmforless?
