Motor is out
Old Nov 14, 2009 | 07:50 PM
Southpaw40's Avatar
Default Motor is out
Finally got a chance to work on the camaro today and finish taking the motor out. Here are a few pics if I did it right.
Attached Thumbnails Motor is out-6e2ab78f16f4.jpg   Motor is out-11f8adbc485e.jpg   Motor is out-camaro.jpg
Old Nov 14, 2009 | 08:28 PM
osduck5's Avatar
Looks like you have the hard part completed. Congrats!
Old Nov 15, 2009 | 09:39 AM
Southpaw40's Avatar
Thanks Osduck, gonna start tearing the motor down tonight and see if I should fix this one or junk it and get a salvage motor..
Old Nov 15, 2009 | 10:18 PM
osduck5's Avatar
Do you have a special tool to remove the main bearing caps? I have mine torn all the way apart except the crank is still sitting in the block. Apparently the mains are pressed in and you have to get a special tool to remove them. I have no idea what that tool is.
Old Nov 17, 2009 | 04:35 PM
pwcfire's Avatar
I ran into that problem on the main bearing caps. My special tool was a vise grip and a pry bar. You have to be VERY careful while prying up on the vise grip but it worked and nothing got damaged.
Old Nov 17, 2009 | 04:44 PM
Jonny Dubyah's Avatar
Nothing better than rigging stuff to work..better sense of accomplishment lol...
Old Nov 17, 2009 | 05:15 PM
Southpaw40's Avatar
Thanks, for the heads up on the main bearing. I still have not got the chance to go back out to the garage and start tearing it down. I was gonna go out there tonight but I am tired an its not going anywhere so it will happen this weekend.
dukeacell
Jan 3, 2014 01:59 PM
sksimmortal
Apr 6, 2012 12:32 PM
Stix80
Jun 7, 2009 08:49 PM
bubnchris1922
Apr 29, 2009 11:05 AM
ryan88z
Jul 10, 2007 10:16 PM
