Gear drive
Old Nov 11, 2009 | 12:34 PM
Jr. Mechanic's Avatar
August 2009 ROTM
Default Gear drive
So thinking I was doing myself a favor and getting an amazing deal, I purchased a new Jegs noisy cam gear drive, Trans Dapt Slam Guard oil pan, and a billet bow tie timing cover, all brand new, for $120 bucks.
When I got home, I realized the oil pan was for a passenger side dipstick and the gear drive said for factory roller cam
What's different about the factory roller cam gear drive?
Old Nov 11, 2009 | 12:57 PM
Do you still have a functioning knock sensor? The harmonics from the gear drive picked up by the knock sensor will screw up your timing.
Old Nov 11, 2009 | 01:54 PM
August 2009 ROTM
No, no knock sensor. So will this work on my engine? It's a 1974 350 4 bolt with a flat tappet hydraulic cam.
Old Nov 11, 2009 | 06:50 PM
No it won't work. A roller cam engine has a thrust plate that bolts to the front of the block over the cam. Front of the cam design, as well as the cam gear is different: Roller & Flat Tappet Cams
Old Nov 11, 2009 | 06:52 PM
August 2009 ROTM
Ahh, I see now after looking at the differences. Thanks!
94z28chevy
Oct 11, 2015 06:20 PM
94z28chevy
Sep 20, 2015 08:03 PM
mab6680
Jun 29, 2013 07:15 PM
Chia219
70-81 Transmission & Differential
Mar 2, 2013 07:05 PM
riss1978z28
May 21, 2012 02:27 PM
