V-6 3.8L Car starting issue
Old Nov 9, 2009 | 12:07 PM
-=Scorch=-'s Avatar
Default V-6 3.8L Car starting issue
Here's what's going on. Just recently after the temperature seemed to drop between 0 and 10 degrees Celsius, my car is fighting to get started. after three tries the car will start. I let it run for five minutes and stopped the engine. When I tried starting again it starts up perfectly. It's been doing this every day for the last week or so.
Today it's a balmy 15 degrees Celsius outside, I haven't touched the car for two whole days and the car started up perfectly this afternoon.
Any ideas where I should start?
Old Nov 9, 2009 | 12:32 PM
evilkal's Avatar
Is the fuel pump kicking on? It may be going out and taking a minute to build up pressure
Old Nov 9, 2009 | 04:19 PM
Jonny Dubyah's Avatar
Im having a similar issue..its not bad just seems that since its been coolng off the car doest want to start right up (it used to start within 1-2 turn overs) i wouldnt say its havimg "problems" starting..just not as easy as it used to be.
Old Nov 9, 2009 | 05:30 PM
Toneman07's Avatar
any codes??? sounds like crankshaft position sensor to me
Old Nov 9, 2009 | 06:00 PM
Its not a pump issue for me..i can smell te gas if i keep cutting it off too early..no codes..it did it on the cooler nights of the summer when i had it too..
Old Nov 9, 2009 | 08:28 PM
Toneman07's Avatar
might be a vacuum leak somewhere
Old Nov 9, 2009 | 08:30 PM
Toneman07's Avatar
just a random thought have u had battery and starter tested?
Old Nov 9, 2009 | 09:54 PM
-=Scorch=-'s Avatar
I finally get some time tomorrow to take it into the garage and poke around. Car worked fine all day today.
Old Nov 10, 2009 | 12:46 AM
hmm..battery may be possible.no idea how old it is..im leaning aginst vaccum leak..its only a problem on start up..ill get my bttery tested at lunch tomorrow...
Old Nov 11, 2009 | 12:22 AM
Dznuts's Avatar
X2 mine is having that and thats what my problem is haha
