p0446
Old Nov 4, 2009 | 07:10 PM
Xx3800xX's Avatar
Default p0446
okay so this is the code that popped up from check engine. p0446. something to do with EVAP..stupid emissions crap. i replaced my fuel cap (most common problem) and waited a couple weeks. its still stuck on check engine. so i need some help, what should i look to replace now? any others had this code in the past?
Last edited by Xx3800xX; Nov 5, 2009 at 11:01 PM. Reason: i noticed my post wasn't very informative
Old Nov 8, 2009 | 05:23 PM
osduck5's Avatar
check the EVAP vac and vapor lines for leaks or blockages. Check the vapor canister to make sure it is not damaged or leaking. A stuck closed evap vent valve and fuel tank rollover valves can also set this code.
saltflat
May 10, 2013 04:13 PM
