build thread!
Old Oct 18, 2009 | 08:07 PM
redhoss02's Avatar
Default build thread!
i have a 1988 irocz z28 that i am re-furbishing! i started with pulling the 305 tpi. i bought a 350 long block and installed everything from the 305 onto the 350. the 350 has been dropped in and the motor mounts are bolted up thats it. im trying to hook up all the sensors and vacuum lines and all connectors on the wiring harness. i have already installed 24lb injectors and i am trying to find a 350 chip for the ecm, knock sensor and module. i was going to see if there was any way you guys can hook me up with some under the hood pics and close ups of the sensors and along the tpi so i can see where most of this stuff hooks up to. i know this might be a pain in the a$$ but it would really help me out big time. my setup has the cold start injector on the driver side and i found where those connections go but on the passenger side there are also 5 connections and i only have 4 injectors???? any help will be greatly appreciated. this was a project but im trying to get it running asap as a daily driver and do the mods as i go. thanks a million guys!
Old Oct 19, 2009 | 03:51 PM
redhoss02's Avatar
well i cant seem to find a t5 anywhere and cant really afford $500 to rebuild it so im open to suggestions!
Old Oct 19, 2009 | 07:02 PM
redhoss02's Avatar
build thread!-digital-camera-169.jpgis this the knock sensor module i already have one and this is an extra but how do i know if this one is for a 350
build thread!-digital-camera-170.jpgwhat sensors are suppose to be here i think what is in there is wrong! i am just going to buy new ones but i need to know what they are!
Old Oct 20, 2009 | 11:29 AM
newtocamaros's Avatar
i had this big long reply typed out and realized it was all wrong
Old Oct 21, 2009 | 07:49 PM
redhoss02's Avatar
sounds like something i would do! disregard the previous posts i already figured out the answers! but i have more questions and will probally have alot more to come. although i am still trying to find the knock sensor module! does anyone have pics?
Old Nov 21, 2009 | 09:07 AM
draggo144's Avatar
Apparently they changed up the knock sensor position/workings between 88 and 91, because mine is completely different from yours. I have a knock sensor behind the passanger side motor mount, right in front of the starter. Someone told me one time that the 'module' (which I don't have) was going to be on the drivers side firewall, which might be where yours is. Your best bet on the wiring is to spend the $150, and buy the shop manual and an OBD1 reader to tell you what sensors are reading and what one's aren't reading. I didn't buy the reader till the car was finished, and it would have saved me tons of money and time. The shop manual is a great investment also, it's like a bible over your camaro. Tells you everything you will ever need to know and then some about your car.
lownoma
Apr 28, 2023 07:36 AM
rydeer
Aug 1, 2012 06:41 PM
Dadz67
Mar 22, 2012 02:45 PM
Jh8909
Jan 20, 2011 01:45 PM
caseyzizzle
May 5, 2010 02:00 AM
